Federal Signal MicroPulse LED Hood-Mount Warning Light, Amber
main picture
We compared price of Federal Signal MicroPulse LED Hood-Mount Warning Light, Amber across hundreds of online stores. We found Federal Signal MicroPulse LED Hood-Mount Warning Light, Amber in 1 store with lowest price $97.95 in AW Direct. For detailed price comparison of Federal Signal MicroPulse LED Hood-Mount Warning Light, Amber check table below.
Merchant Price -
AW Direct [show price]
Federal Signal MicroPulse LED Hood-Mount Warning Light, Amber description from AW Direct
12 flash patterns .2 amp at 12 VDC .11 amp at 24 VDC 12/24 VDC 2.5L x 1.1H x 1.5D Equip your vehicle with Federal Signal MicroPulse 3 LED Warning Light. The additional warning signals help improve visibility and your safety. This hood-mount light can be programmed to operate as a single unit or in sync with multiple lightheads. Fully encapsulated waterproof housing. Amber lens.SAE J845 & J595, Class 2. Imported.
Customer review
The transport was done quick , the parking & signal light assemblies look like on the image , pretty good quality, I wouldn't mind purchasing from the same manufacturer again.
